DSM Asma?!?
ktowntalon
52
Jun 13, 2006
Kutztown, Pennsylvania
My car has the infamous DSM asma. I hate it. It only does it when I'm moving thought. Is there some kid of velocity sensor or something, maybe a speed sensor that is making it do this. Why does it only have asma when it is moving. Also the check engine light comes on when I go WOT for a little and then goes away after the car is restarted.
Help
thanks
ktowntalon:talon:
Could your asthma problem also be a fuel or ignition problem? Remember that there are two other parts of the equation. It may be good to check your fuel system from the pump and pickup to the filter and injectors. On the ignition side, check your spark plugs, plug wires, etc.
You need to define how exactly your car has "asthma". What are you experiencing (in detail)?
After driving or even just pulling out if I would come to a stop at a light or just put the clutch in while moving the car's idle goes up and down. It idles from around 750-1500. The car just doesn't stop doing that until I come to a complete stop.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
