2G Drum to Disk brake swap
lesb1978
59
Jan 3, 2005
Lake Ozark, Missouri
ok i searched and came up with no matches i know its possible but how difficulft and what parts do i need to convert my rear drums to discs really interested in this just trying to find out what components i need
If your NT don't ever forget to search on 2gnt.com they usually have something if dsmtuners doesn't, and dsmtuners have a lot.
http://www.2gnt.com/www/files/reardisk.htm
That should do you good, if that link doesn't work, just got to 2gnt.com and look under mods...handling mods.....then the thread.
All though while your doing that, you might want to consider upgrading to a GSX caliper in the front at least. 2piston calipers with some GSX cross/drilled rotors,and steel braided brake lines. You will definately feel a difference.
for that install, you will find it in the tech guide on this site, so don't say you didn't search.
thanks i really appreciate the link and for some reason i always forget about 2gnt
thanks again :thumb:
  • For sale 1g 1g 90-91 fiberglass hood
    Got this hood new in 1999. While it was fresh I reinforced the fiberglass webbing on the bottom...
