Drive problems
SkinnyJ
Feb 4, 2012
Winnipeg, MB, Canada
Why would my 1995 Eagle Talon TSI AWD lose drive to all 4 wheels without the clutch slipping? Any suggestions will be appreciated! Thank you.:aha:
it is just putting power to the rear tires...once the car hits 4000rpm????? then does a monseter burnout and thats all it does..... any help would be much appreciated
okay i will try to see if it is a broken cv joint, and where is the front diff???? the axles come out of the transmission.................:hmm:
Check your rear axles, front axles, Tcase output shaft and input sleeve splines/trans output shaft splines, and if none of those are broken or stripped, I would look at trans or clutch.
What clutch is in the car?? You could have stripped the hub or sheared the rivets on the hub causing these problems.
Tim Zimmer via Evo Phone
it has a findanza stage two racing clutch with a findanza 11 pound flywheel :hellyeah:
and everything is looking good (axles, drive shafts, transfer case, and cv joint) is there anything else to check before pulling the trans??? :confused: .... im thinking trans :ohdamn: but i hope not :pray:
