DRag radials on a stock differential?
92 EcLiPsE
Apr 13, 2006
Howell, New Jersey
I have a 92 fwd turbo eclipse. I was curious if I put drag radials on the front if it would damage the differential. I was curious if I needed an lsd to do it. Thanks in advanced!
Anthony
Should be okay. The reason you would use the drag radials is because you don't have an LSD. Be carfeful not to ruin your clutch, or toast the entire tranny with a broken shift fork or some other problem.
You will be fine on pretty much anything the main thing that would hurt the diff. is if you launch and only one tire spins the diff pin can seize and the throw it threw the case. So just don't spin one tire to long or to often. Good luck.
