Drag DR-38 Pic Request, and Hub Ring Question
Paintballaa5
535
273
Jan 23, 2012
Houston, Texas
Looking into buying some Drag DR38 wheels, and i've only run across one DSM with them on it. I would like to see them on some other cars before purchasing.
Also, just now learning about hub centric vs. lug centric, am I correct in needing a 73mm OD/67.1mm ID ring if the wheel has a hub bore of 73mm?
These to be exact:
Hub Rings 73mm OD 67.1mm ID, Set of 4 Hub Centric - Fast Wheel Accessories
Thanks in advance!
-Logan
