Downpipe options
kevingst
494
3
Feb 4, 2003
Olive Branch, Mississippi
I'm running the Thermal 3" catback w/ the 2.5" neckdown. I saw that on RRE they sell the 3" weld-on flanges for $12. I'll be getting rid of the neckdown. I will be going 3" turbo back, with a 3" hi-flo cat/ test pipe (will switch between the two depending on occasion). What dp's do you guys use with the Thermal system? My main concern here is lengths....making sure everything will connect up good. I tried searching around, but didn't quite find what I was looking for. RRE's dp's look like they'd work nicely and aren't priced too bad either. Any opinions on them?
I used a meghan racing downpipe off of ebay worked great, its 3" too. It had to be cut and welded though because it was designed to remove the 3" cat.
