Double check before i order
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Moparpartsoverstock.com yas carrier bearings for 70ea but i want to make sure they are the right part. It lists part number MB505495. Being they are $20 cheaper than anywhere else i figured i better ask you guys first.
Parts ordered with Insulators.. total 182 to my door. seems like a good place for parts for our cars. they have about everything you could need.
so you're doing carriers but not u-joints ? don't forget you need to get the lobro off to do one of the carriers, and with that is a non-reusable nut and washer. so you need to order those from somewhere too.
should have just gotten the jnz kit and done it all once, the right way.
Soooo spend 400 when i only need 185 in parts? U joints are in great shape. Replaced the one at transfer case already and others were solid. Ill buy the $35 joints as i need them but right now i dont.
Not trying to be rude but no need to throw money away when i can replace things as needes.
Not trying to be rude either, but looking at the driveshaft again, you'll need both new NON-REUSABLE nuts to get to the carrier bearings. Plus you won't know if your joints are good/bad until the driveshaft is off the car and you can move the lengths on all axises to verify.
