Dont know what to get
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
Im getting a new manny and 02 installed and the guy says Im going to need some oil drain gaskets for the j pipe. I dont know what he means or if I heard him wrong. What are these gaskets and where can I get them?
Those are two seperate gaskets. The j-pipe goes from the turbo outlet (compressor cover) to the intercooler. The oil drain goes from the center section of the turbo down to the oil pan. The drain requires 2 gaskets. JNZ Tuning or Extreme PSI would be your best bet.
JNZ has the oil drain gaskets for $1.39 each and the j-pipe gasket for $2.59. http://www.jnztuning.net/index.php?cPath=21_40_204&osCsid=ca9d5e2a456c87e7e859442746c01a7a
ExtremePSI has the oil drain gaskets for $2.00 each and the j-pipe gasket for $3.25. http://www.extremepsi.com/store/search.php?mode=search&substring=&veh=1G+DSM&cat=756&type=Gaskets+%26+Seals
