Dont know 1g or 2g
tsitalon03
259
Jul 15, 2007
SouthRiver, New Jersey
I have a 2g talon with a 6bolt swap. I have to get a new coil pack, clutch slave cylinder, and an external oil cooler. Do I get them as 1g parts or 2g?
You will still use a 2g clutch slave cylinder because it is attached to the tranny not the engine.
And if you are referring to the oil filter neck you will need one for the 1g motor.
the slave if it's the 6 bolt tranny which i assume it is then go 1ga with the slave.
external oil cooler you most likely will have to custom mount it but go 1g because then the oil filter adapter fittings will match up.
Either coil pack will work, but a 1g pack will mount to your 1g intake. A 2g will need a custom mounting bracket.
Yep dead on with the clutch slave. You need a 2g. A 6 bolt swap only involves the engine not the transmission.
You have to have a 1990 oil filter housing (part # MD 157670) for an external oil cooler.
1g intake manifold?
Its a 2g tranny.
So....1g coil pack....2g clutch slave....and 1g external oil cooler
