doing potentiometer mod on 97 what wire?
ok well i found out which one it was so i thot i would post it just incase someone need it or was searching for it one day well on my 97 it was the orange wire with gray strips i think on any year its the orange wire!
I did the pot mod and put 24,000 miles on my motor no problems so far and I think its fine to run it despite all who say not to do it. Just make sure you tune the the car befor you hammer on it. I went from 11.5/1 air AFR to 12.8/1 when I put mine on took it out and and tuned it to 11/1 AFR and its held there ever since. 5 bucks is alot cheaper than 1000.00 for a dsm link. Though your car may act diffrent than mine so check the AFR after a couple thousand miles and then again a few thousand miles if it holds then you just saved 995.00.
  • Wanted 6 bolt NT water pipe
    • chrisman287
