what is the potentiometer mod?
If done properly it will help eliminate the random misfire that is commonly found when a 6bolt swap is done on a 2g.
what is the random misfire from? What else can solve this? DSM link? Im interested.
what causes the random misfire? What else can solve this? DSM link? Im interested.
random missfire is exactly what it sounds like a random missfire usually at cruising speeds around 3500rpm. Yes link can get rid of it but if your not doing a 6bolt swap you really have nothing to worry about.
well the car im looking at has a 6 bolt swap so... Guess ill have to look into it. How does dsm link fix the problem?
does the computer not register something? Does the knock sensor activate for a second retarting timing? What goes on? Does anyone know? Does everyone at one point see this?
ahh so the ecu actually scans for the misfire, and if a glitch or whatever happens that signal goes back and start the ongoing process? Sounds simple enough. Since the dsm link seems like a have to have item, it shouldn't be that bad. Thanks man!
