does the spyder gs have stock rear sways?
formulav893
47
Jul 5, 2006
surrey,
havent crawled under my car yet, but wondering if the stock spyder GS has rear sways? if not does it have the mounts/holes for it? would the stock gsx/gst sways be sufficient?
No, the Spyder GS's do not come with a stock rear sway bar. One can be added, however, because the parts needed to do the conversion match with the Spyder GST.
2 Rear Control Arms MR131754 $55.00/each
2 End Links MB892982 $15.00/each
2 Brackets MB515245 $ 7.00/each
4 Nuts MS440504 $ 1.00/each
4 Bolts MF241251 $ 1.00/each
I found this info on this link. http://diy.prostreetonline.com/techtips/showarticle.asp?articleid=15
thanks for your post, and the link, those parts/numbers listed are those mitsubishi part numbers? is there aftermarket equivilent available? because local dealers charge an arm and a leg.
  • Wanted 6 bolt NT water pipe
    • chrisman287
