Does anybody have a spyder they're parting out?
Status
Not open for further replies.
kenjiw
125
Jul 12, 2013
Markham, ON, Canada
I need this part specifically, driver side the raising arm bar that lifts the roof up and supports it when it comes down heres a few pictures. Stangmurdera/Miller Import parts cant find one in good condition either so i need some help here.
That's a link you have posted here that connects to the bow. You can order a set on ebay that someone made specifically to fix that problem. I don't have the link to it but search on ebay. You have to drill the bolt out that holds the link and install the new one; the seller who sells the links on ebay comes with bolts/nuts to replace your drilled oem bolt.
Mine also bent but after replacing it, it still bent when opening the convertible so I just never open the top.
the bar is literally snapped, and i cant find anything on ebay.
Keep looking. Im 110% positive it should be on ebay. I don't have good signal here so searching is B***H.
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
