Does the 2g Throttle Body Arm Bolt on to the 1g....
x427boricuaking
Feb 14, 2006
orlando, Florida
My Friend has a 2g Motor an I have a 1g.. I was wanting to know since the 2g Throttle body arm allows more flow can i put it on my 1g no problems? and do other little components like that bolt right on no problems?
Are you talking about the elbow that connects to the IC piping and the throttle body? If so, yes it will bolt to a 1g throttle body, however it won't fit your stock IC piping.
O ok cool thatnks that helps allot!! and also i wanted to know if the Exh Manifold will fit on my stock 14b... i got sum plans i wana try to get 2 low 14's high 13's
if you think about it too on top of what was said above you should think about putting studs on instead of the factory bolts!! i pretty sure they are 8x 1.25 for size and also for some real good insurance i put heliColis on all the threads!!! and that too is a 8x 1.25 the kit part number that i have is 5546-8 i got it at Oreilly auto parts for a killer deal because a fellow dsmer works there so mine was only 20 bucks!!! LOL
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
