does anyone know
97eclipse4g663
Jan 23, 2011
varney, West Virginia
im new to this i had to replace the clutch in my 97 eclipse spyder 4g63 and i need to know how to locate the place to put manual tranny fluid in at and what to use in it
Do you still have the starter plate in between the engine block and transmission? Are the dowel pins for aligning the engine and transmission in place? Are the transmission to engine bolts torqued to spec? Are the starter bolts torqued to spec? Are you sure you have the right starter?
everthing that i know of what u said is done... i called the company and its the right flywhel... called the parts store and the starter is te right one... so i dunno about to give up
