Does anyone have a pic of this housing installed
sergiosdsm
110
Nov 5, 2002
New Jersey
I am wondering if anyone has a pic of the rnr racing o2 housing installed on their car because I want to make sure I wont have any issues changing springs on the external wastegate if I get one and if the fitment is good. thanks
The only issue with that housing is that you would not be able to use a tial 34mm gate if you have your PS pump there still as it will be to long. The tial needs almost 6 inches and from the plate to the PS pump is a total of about 6.5 inches, so unless that waste gate pipe is actually bent at 15 degrees twordes the front of the car you will have to make sure to get a waste gate that will fit that uses only like 3 inches or so since that pipe looks like it is almost 3 inches long ( unless you drop the ps pump :p
