Do Not Post a Question Here - Read the Red Bolded Text Above!
2gGSX
1,956
31
Feb 15, 2004
St. Louis, Missouri
Day 1
Only got like 2-3 hours of work in since I had to fix my dad's car too. Got the radiator, downpipe, and turbo setup off so far. Glancing at the valves it looks like cylinder 4 has some beat up valves, which is no surprise since there's a giant hole in front of where the 4th rod would be. Turbo was pulled while attached to the manifold, so I didn't get a chance to pull the feed line to inspect the center shaft for damage.
There was a good bit of wiring that looked like it might have gotten singed (slightly melted insulation). I need to remember to take a better look at them to make sure nothing got damaged. If that's the case I'll probably loom them properly this time and call it a day. Otherwise it'll be an awesome wiring project to redo half my engine bay harness.
Currently I'm looking at two motors on sale. Specs for anyone who care--
Specs on block:
fully machined 2.4L G4CS block (6-bolt)
Manely custom 10.5:1 pistons /L19 wrist pins
Manely custom TurboTuff 156mm Long rods
Eagle 100mm Crank
Kiggly Race main girdle
ARP main studs
ACL trimetal bearings(rod/Main)
-12an block breather
OEM oil pump W/gears
OEM Fwd facing oil filter housing with new OEM Filter
Specs on head:
2g JG engine dynamics CNC flow bench tested head
CNC race PnP JOB (Curt Brown specs, ported for maximum VE , not hogged out)
Ferra 1mm O/S intake valves
Ferra 1mm O/S exhaust valves
OEM revised Lifters
HKS 272 cams
Kiggly Racing Beehive springs and retainers
2.4 DOHC cam gears (use 2.4L DOHC OEM timing belt)
ARP L19 headbolts (machined for 6-bolt head studs)
Felpro Permatorque MLS
Almost perfect setup.. just unsure of the Manley pistons. Something proven like a Wiseco 1400HD would've been ideal. The information I've about the pistons is that they're a 2618 alloy with 22mm wrist pins, 0.210" thick (vs. 0.225 on the Wisecos) but made of 9310 alloy (vs. chromoly on the Wisecos.. which is actually a weaker material).
Groden rods
Mahle pistons
ACL tri-metal bearings (rod and main)
Stock head
FP2 cams
ARP head studs
All new gaskets/freeze plugs
Put together by the same place that does johntsi's machine work
0 miles...just idled
Light as hell bottom end. Would rev a lot better. Not sure about the specs on the Mahles though other than that they're ~300g vs 330 on the Manleys and ~350 for the Wisecos.
This next week I'll hopefully be getting a cherry picker from Jimmer since his grandma's pissed he took over her garage. I'm going to try to take out the surge tank and intake manifold, and basically get the car ready to drop the transmission out first, and then the motor.
