DO I NEED MAF Translator
dsmimports
Sep 9, 2005
PROVIDENCE, Rhode Island
I was thinking about the mas and MAF Translator. Where do I put the mass and translator Do I need it or can i take it out and if I do need it how much hp will I gain out it or will the car run right?:dsm::thumb:
You are obviously new? Its cool ill just let you know you should do some research on this website because our topics usually answer anything you wanna know.
Anyways. The maf-t is a tuning devise that is a little bigger than a pack of cards and it takes a signal from a MAF( that are made for GMs.) and tweaks it alittle bit and then sends it to the ecu so it will either put in more or less fuel. If you are all stock then it won't really benefit you. You need a datalogger or wideband o2 to see what is going on when you mess with the settings. This post will answer all your questions. http://www.dsmtuners.com/forums/new...-maft-questions-merged-gm-maf-translator.html
The most you'll gain is to be able to run high boost because 2g MAS is limited to about 30 psi I believe. Also you get to vent if you put the GM MAF after the BOV. And you might gain slightly more airflow.
I thought newbs can't start threads? There is a button near the thread start button called Search 1st.
How do you think the Newbie forum works?? If noobs couldn't post new threads there, that section would be pointless...
Put the mass in your upper intercooler pipe after the blow off valve.
If its the original Translator mount it on the firewall and wire it accordingly.
Thing that you will gain the most from doing just the conversion is some good spool up and being able to vent.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
