Do I have a clutch problem?`
craziloki
109
May 13, 2009
York, Pennsylvania
Back in april I installed a pucked clutch and new pressure plate. Both are rated for 355hp. Im not pushing that much yet. Anyways my issue: Recently (like 3 days ago) I noticed when I am coasting (in gear/clutch disengaged) I can feel a slight resistance at times and the RPM gauge climb accordingly anywhere from 500-1000 RPM's. Pushing the shifter into neutral stops this. There are no leaks from either cylinder and I have flushed my clutch fluid. Any ideas? Thanks!
i was thinking that is could be my master/slave cylinder but there are no leaks.. Also, wouldnt that cause the motor to bog down, not rise in rpm's?
