DN Performance Install Problems
kahl23
1,093
14
May 10, 2004
Wellesley, Massachusetts
Hi everyone, I just went to bolt my turbo up to my shiny new DN Performance exhaust manifold and I ran into a very odd problem. The equal length runners of the manifold hang over three out of the four holes in the manifold flange, preventing me from dropping the turbo bolts down. Has anyone ever experienced this problem and if so, how the hell do you fix it? Just so you know, I've already considered reversing the bolts, running them up from the bottom. This won't work because the casting of the turbine housing prevents this on one of the bolts. Thanks for the help.
you use studs install them in the turbo. Then slowly lift the turbo into place and thread the nuts on.
you need to run shorter bolts, that manifold is a pain in the ass, i hated mine, after putting it on and taking it off twice, i sold that piece
  • Wanted 6 bolt NT water pipe
    • chrisman287
