Resolved Disassemble 1G rear passenger interior panel.
MysticMarine
179
Jun 20, 2011
Dallas, Texas
I need some PDR done on my mint laser because my father in law backed into the car. yes, this is the 22K laser(now 28K). I need to remove the passenger rear interior panel. The plastic piece that has the rear passenger speaker attached to it. I don't want to start ripping things apart so can someone give me detailed instructions on how to properly disassemble this piece with out breaking it.
Thanks in advance,
-A
BTW, I love my DSM.
There should only be push type clips/rivets (whatever you prefer to call them) that hold that panel in. If you are good with small screw drivers or have access to an interior trim tool, that should be all you need. At least that is all I remember needing on my Talon.
Also, remove the seat bottom, there are 1 or 2 screws that hold the panel in place down there that need to be removed also.
It was easy, thanks guys. I only broke one little tab then I realized it's a push tab. DSMs are built so much better than Fox Body Mustangs. The interior is nice to work on and everything alines.
