Daveed
- 231
- 0
- Feb 25, 2005
Olympia,
Washington
Check out the water pump I just took off! The vehicles been sitting for 2 years. I've never seen one this bad.
Seeing how much corrosion and sludge is in this part of the cooling system makes me a bit concerned about clogging the radiator and heater core as soon as I get this thing back together.
Anyone got any ideas on how to deal with massive amounts of corrosion in the cooling system? Yah, a flush is obvious required but DANG! Is there anything else I can do to help minimize the clogging that is likely going to occur?
PS I have it up on jackstands in the garage right now doing a mini rebuild of the motor (head off etc) so I can't easily roll it outside yet.
LACQUER THINNER!! might mix in some "rust converter" to aid in killing any rust in the system... I honestly don't know what this would do, but if i had to pick 2 things to put in that MIGHT clean up and fix what you have and not damage anything(except rubber seals), that would be the 2. Good luck man, I'm sure even a flush and a new pump and some seals would make a worked of deifference..fluch it , then if it clogs, take it to a radiator shop and have it professionally cleaned.
