Direction of flow through fuel rail.
Katelynrose269
48
3
Mar 24, 2012
cathedral city, California
Can the direction of the flow through the fuel rail be reversed so that it flows in from the drivers side and out the pass. side??? Just a thought that popped in my head while lookin at it.
Can it be done with modification to the feed and return? Yes. But unless your working with a really one-off setup, it's not very practical and wouldn't give any benefits.
One good reason to do it is to utilize the larger diameter feed line as a return line if you are running an aftermarket feed line. By doing this you would pretty much never have to upgrade the return.
