difference in 1g trans by build date
JFatch1890
332
3
Oct 31, 2008
Stratford, New Jersey
i have a 92 talon 5 speed,and have parts car with good trans. the build date is 6/90..... so is this a 90 only trans or is this a 91-94, and also able to use in my 92 without using cables?
Check the transfer case, if it's all steel it is a 23 spline output shaft. If it's aluminum it is a 22 spline output shaft. Your 92 is a 23 spline output.
you can easily tell by lookin at the shifters in the car take the plastic cover off and 90 ans 91+ are way diff.
