2G Dies on open loop
95TSIAZ
Nov 21, 2026
Waddell, Arizona
Hello, I just got my first DSM! It’s a 1995 Eagle Talon TSi AWD with a manual transmission. It runs great once it’s warmed up, but when starting it cold, it misfires, idles rough, and sometimes stalls.
So far, I’ve replaced:
  • ISC motor
  • TPS
  • O2 sensor
  • Spark plugs (NGK BPR7ES)
  • Spark plug wires
  • Battery
Does anyone have any ideas on what could be causing this? Thank you
Any stored codes for MAF, lean/rich A/F codes, ECT, misfires, etc...?. Did you inspect the throttle body for proper operation and build up? Did you check for vacuum leaks? What vacuum are you reading when cold? What's you fuel pressure? Give a little more details..
- Are the small coolant hoses still connected to the throttle body (TB)? You need them.
- But check post's 2 stuff before the item below.
- A way smaller possibility (and perhaps long shot after you've checked everything else, so make this the last thing) is perhaps the PO (through frustration of never getting it set right) permanently closed the TB's FIAV (fast idle air valve) plunger against its seat (so no air could go from one side of the TB's butterfly to the manifold side to raise idle when cold): https://www.dsmtuners.com/threads/fiav-adjustment-disable.320951/
