Did I blow my turbo?
Nando15v89
58
Jan 9, 2013
Whittier, California
So today I was switching out my oil pan gasket and turbo oil line going to the oil pan ### they were all leaking and changed my oil pressure switch but I added the oil back in and fired it up I forgot to turn the key a bit to get oil in the turbo and now the car has no power and when I revv it to about 3k it has a loud rattles from the turbo area and I drive it once I switch gears in higher Rpms the car just dies out on my boost gauge the vacuum was always at 20 not its at 15 or less i don't know but ### do you guys think? Oh yes it's a 99 gst with stock t25
Any smoke coming out the exhaust? I would take off the intake pipe and see if your turbo has bad shaft play, give it a light spin by hand and see if you hear of feel anything. Might need to rebuild it.
Heres a video
YouTube
I just checked the for shaft play and there's none but I also wanted to mention we changed all the belts and when trying to loosin the power steering belt going to the harmonic balancer we turned it counter clock wise accidentally trying to get it lose would that mess up the timing?
That doesn't sound like the turbo to me. It sounds like its coming from the head. Hopefully you didn't bend any valves up turning the crank the wrong way. I was told it shouldn't have unless it jumped timing.
If you turned the power steering pulley its no big deal.
Did the turbo wheel spin when you checked it for shaft play?
Is your wastegate stuck open?
I cant open the video for some reason.
Do a boost leak test. You already know your vacuum is less than before. That should be the obvious first thing to do. I couldn't open the video either. Also, make sure you timing is correct.
Doesn't sound anything like a boost like from the video. Not saying he doesn't have one, but there is definitly something else going on. Rod knock maybe?
My timing is not lining up i just checked and in the video it sounds like a knocking sound when I revv it up were do I go from here
If your timing is off I'd get it checked for bent valves and any other damage to the motor. Something is going on from that sound! Hope it isn't rod knock, if so its time for a rebuild. I'm not a expert by any means, but it doesn't sound good.
  • Wanted 6 bolt NT water pipe
    • chrisman287
