Dejon Tool SMIC--->good for my setup?
VRMAN
634
3
Apr 8, 2003
Daygo, California
If you check my profile you can see my full modification list. I currently have the 'modified' dejontool SMIC with the larger inlet tube and outlet elbow. I would like to be able to run 19-20psi on pump gas and know this just isn't feasible with the stock IC core. I paid full pop for my dejontool UICP and LICP so I would like to be able to retain a SMIC setup for this reason (also had an FMIC setup stolen, don't want the attention)
Would the dejontool Super Sidemount, found here:http://www.dejontool.com/DSM-1g-SMIC.htm work for my intended purpose or will I heatsoak that as well? My turbo isn't really big but I am not an expert of HP to IC volume needed to run high boost applications.
Only other plans for the car are 264/272 cams.
*thanks in advance for any input, please note I have researched my choice and have my reasons, opinions about the price of the IC, how the Supra SMIC is better or 'just get an FMIC' are not needed for this particular thread
Well, running a sidemount intercooler may not be optimal for your setup, but I understand you sentiments, Im in the same boat.
You could try that Dejon Super sidemount, and I think youd be ok. Another alternative would be the ADFX sidemount upgrade, which they claim outflows the supra cores. The supra cores support 350+ horsepower, so thatll give you an idea.
Check your PMs.
