Dejon Tool O2 eliminator DP
JAX2Ganey
221
Oct 14, 2007
Hyattsville, Maryland
Does anyone have a Dejon Tool O2 Eliminator Downpipe for a 1g FWD? Ive checked their site and called them. The guy said they dont make them anymore because they only sold a few a year. I think they are an awesome solution for a O2 housing and downpipe set-up.
The only issue with them is the fact if you need to remove your down pipe and don't have a flange elsewhere after the part that connects to the turbine housing, you will need to have the fun in removing the 4 housing bolts to remove it.
2 bolts or a v-band is easier to remove than 4 bolts off the side of the turbo.
That is a very true statement. I have an WH1C with a BEP housing(not installed yet) and im trying to figure out what route I want to go with my manifold/wastegate/o2/downpipe set-up. Another problem I could see with the Dejon DP is, I would want a recirculated wastegate tube. I initially wanted to go with a v-banded outlet for the o2 and a v-banded inlet for the downpipe. I think what attracts me to the 'o2 Eliminator', is the simplicity of the combined two pieces.
