Dejon Tool MAF blow-through w/ABS
Talon4ever
111
Feb 15, 2004
Houston, Texas
I was wondering if the Dejon Tool blow-through pipe will fit with ABS? It looks sort of big and I am not sure if it will fit. I called Dejon and they said they have put them on cars without ABS but some of there customers have put them on with ABS. If it will fit, what modifications do you have to make to the pipe or ABS unit? Thanks for the help.
I am running this setup with ABS and had no problems. The only thing was the positioning of the MAF. The connector of the MAF has to be turned a certain way.
Really no problems though! Go for it!
I used to have ABS in my 93. Let me tell you, I hated that POS.
It's a several hour job to take it out, but I know that I dont regret it. The ABS in the 1g's has a damned slow pulse rate anyway.
Is it necessary to remove the ABS? Why would you want to do that? Will this setup work without removing the ABS unit?
No, it's not necessary to remove it.
I got rid of it to save weight, to save underhood space, and to make working on the car easier.
