Dejon Tool CIP-1gS Intake Pipe
KaLo
51
Feb 12, 2006
Leamington,
Hey im going to start buying parts for a stage 1 upgrade and I was just wondering if this would be a good intake pipe...the Dejon Tool CIP-1gS Intake Pipe its in the parts catalog
and I also want to know if any of you have this intake pipe and did you get problems with it...thank you:cool:
You'll need a 2gMAS or the adapter, a new filter, and if you're connecting to a turbo compressor inlet less than 2.75", you'll need a reducer/coupler to smoothly transition between the 2.75" intake pipe outlet and the compressor inlet. If you know what turbo you're going with, that will tell you if you need a reducer and what size it should be. If the turbo inlet is more than 2.75, make sure you order the right size intake pipe from Dejon.
Also decide if you'll be recirculating your BOV, keeping the valve cover breather, and charcoal canister, and order a pipe with the tubes you'll be using.
They also note wastegate actuator clearance issues with some pipe/turbo combos, so make sure it will work.
