Dejon Race FMIC
hardware
38
Nov 11, 2002
Wichita Falls, Texas
What's going on all? I'm working on my 91 AWD and I'm wondering who's running the Dejon Race FMIC kit with the MAFT setup and what kind of turbo, boost, knock, etc they're getting out of it. I'm seriously considering picking this up, so any input is greatly appreciated here. Thanks for the space!
My friend bought one and ran it with the maft and a 14b. The car ran really strong. His turbo blew recently and while he is deciding what he wants next we installed it on my car and I have been running around with it. I am running it with a 2g maf and an evo 16g and I give it a :thumb:
Its a nice peice.
I've got the DEJON tool race FMIC. I run the T04b with the MAFT blow thru setup. I also purchased the TiAL BOV, the setup look SICK. The install wasn't a pain, just cut those holes into the subframe and you're set. You might have a hell of a time with PS cooler lines and or AC condenser. I removed all of it so it wasn't a difficult install. I also purchased the aluminum front bumper so I didn't have to mess with cutting the stock one, IMO it's worth the $180.
I ran 20psi and -18 for fuel on DSMLink, I had ZERO knock.
The IC is definitely impressive, even if you're only looking at it :sneaky:
One thing to note, because the outlets on the end tanks face towards your engine bay, the couplers are a little tricky to get to if you happen to blow the lower or upper IC pipe off in that spot. I had to remove my bumper/radiator fan to get to it.
Well, as for AC and PS, I have 2-60 AC plus a sunroof, and I've just about got my manual steering rack too. What kind of air temps were you seeing when you were making your runs? I ask because you're up in Alaska, and I'm heading for the Gulf Coast of Florida.
well thats just great....I'll be at sea level too, only I definately wont have the air temps. Thanks for the info man!
I had the dejon race fmic w/ maft on an fp green. I had to bend the ac line to clear the lower ic piping. I also had to move part of the ps line, but that was because i got a little too agressive with the hole cutter. LOL
