Data logging help
teamslowdsm
May 3, 2004
Temple Terrace, Florida
I have the palm m105 and the mmcd software. Can i clear the CEL? if so how do i do that?
Thanks
brian
I don't know if you can do it with the logger, but I'm pretty sure if you unhook the positive terminal for a few seconds, then hook it back up it will do the trick.
my palm gives you the option. go to diagnostic trouble codes, have it run a test. once the error code comes up you should have an option to clear. once you clear it, it should go away but will probably come back as soon as you restart the car if you have not fixed the problem.
