Dark grey clutch fluid
wangboy925
160
Oct 5, 2006
Melbourne, Florida
I just installed a new OEM mastery cylinder and a SS clutch line that replaces the rubber line (the SS line is about 1 feet long). I put new fluid in the master and a couple of weeks later it turned greyish dark color instead of the clean clear color. I do see a small water looking droplet along the stock clutch line going to the slave cylinder. I think there's a leak when i installed the SS line but the resevior always looks full. I think the leak is so small that the fluid levels dont even drop.
The main problem is that the engagment point on my clutch pedal is going lower and lower to the floor. Installing the new items above is the follow up of this thread: http://www.dsmtuners.com/forums/new...pedal-engagement-point-changed-over-time.html
Im in the same boat. I have no clue why my fluid is changing to the color your describing. Same thing here with the engagement. Anybody else have this problem and find the solution?
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
