cyclone intake or 1g intake manifold
ok. I will try the cyclone. I read about it this morning and There is a way to use the valves in the manifold to come on as your nitrous setting through the dsmlink.
If I'm not mistaken your actuator for the runners on the cyclone actually run off vacuum not anything electronic
The EGR soliniod vacuum regulator is used to control when the valves open.
Not necessarily. You can also use the FPS, BCS, anything that DSMLink is capable of controlling via the Nitrous Control panel. You can set RPM conditions for it to open.
The other method (if you don't have DSMlink) is to use a RPM switch to control those things. You could also a Hobbs switch to make it based on your boost level, but that's not really necessary. The stock JDM Ecu simply activates it at 4k or 4.1k.
It's nothing super magical or boost/rpm/load calculated. Any way you can rig up to open a solenoid at a certain RPM range, will work. You need the vaccuum cannister or a vacuum check valve though. The butterflies are held closed by vacuum. At 4k rpm, the solenoid opens and releases the vacuums to atmosperic pressure. At that point, the butterflies snap open.
Anyways, I have one (cyclone manifold) sitting in my room that I can play around with if anyone has any more questions, or wants to buy from me. Lol. :thumb:
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
