Custom Turbo Back
neuralracing
770
Jul 16, 2003
San Juan, Puerto Rico, Central America
How many Mandrel bent elbows will I need to build a 3" Turbo Back? Will I need a flexible section on the downpipe?
Where is the best place to get an o2 sensor? Is that best to get new or can I get a used one?
Look at your stock exhaust :confused: I reused my stock o2 and it's put behind the cat, then one in the housing of course.
Stock exhaust has several bends... but I want to make it as straight as possible... so I wonder what is the minimum amount of Mandrel Bends I can use.
Also... is a flexible section needed?
I'm looking at doing the same thing on my 2g, not sure how many bends you'll need, but the flex section is needed on the DP :)
  • Wanted 6 bolt NT water pipe
    • chrisman287
