JOEY A
- 1,389
- 1
- Mar 5, 2006
Chitown,
Illinois
Who did yours? Custom cut cams and why did you go custom
With all of the different cams out there for the 4g63, I don't really see much point in getting custom ground cams, unless you plan on making 1000hp.
I think all of the major cam manufacturers will do custom grinds. I know for sure that Crane, Comp, and Crower will do them.
I never really hear it talked about much thats why im asking..
I think no one really talks about it because if NEED something bigger then what's offered publicly (almost .500" lift now) your probably doing alot of drag racing with your car. And giving out your secrets makes it harder to win. I can tell you that shep is running cams from comp that are over .500" lift, but I'm not going to say anything further. I'd contact Comp Cams... just my 2 cents though
Im just wondering if anyone is having cams ground to there setup? I never really hear it talked about much thats why im asking..
. Adjustable cam gears do the rest. There's MORE than enough out there to out cam yourself.Whats more fun, making your own or buying.
Who cares. Hes just asking, not saying hes doing it. Its just a question.
. . . I think it's more fun to create something that perfects your setup and masters your goal and delving into other valve timing is neat. But in the end you'll endup with a cam that has a profile very similar to those offered. The DSM is not a new machine. Far too many have spend far too long under these hoods
.The original poster cares. Why ask?
I'm assuming he's wondering of there's any customization that can yield an "ideal" cam for his paticular setup. The truth is, we all run similar systems to so many others that grds have been designed that accomodate which ever group you are in. All that's needed for personal customization is degreeing to insure what you have or to shift the powerband a little. And believe me, enough is there in a set of adjustable cam gears to give any thought-out cams a shot at being perfect for you.
There's more fun in other aspects of life but we can't get that on demand. . . I think it's more fun to create something that perfects your setup and masters your goal and delving into other valve timing is neat. But in the end you'll endup with a cam that has a profile very similar to those offered. The DSM is not a new machine. Far too many have spend far too long under these hoods
Go for it though! If it makes you happy to play with cam profiles, please share! If you're still asking why one went custom then your clearly looking for a goal to the study and not the in between mush.
