Custom batery connection question
purewake07
81
Jul 17, 2008
ChiTown Suburbs, Illinois
So after moving my battery to the rear i needed to come up with a legit way to connect the four positive current wires together where my batter was under the hood. I came up with this:
Its basically one of those battery terminal connectors but has one place to crimp the main wire and the other wires will be bolted to each side of that. The main plate is made of stainless(AISI 1020) My question is, do you guys think i will i have an Issue with metal on metal connection? I dont know much about electronic materials but i think if you use the wrong stuff it corrodes. Can someone give me a quick lesson on metal connectors?
That will work fine, just make sure to use good connections and make sure they're tight.
Adam
  • Wanted 6 bolt NT water pipe
    • chrisman287
