Crazy Cooling Issues
NickGT20
44
Sep 5, 2005
Media, Pennsylvania
1995 Eagle Talon Tsi AWD Automatic. the trans cooler is external and not built into the radiator..
My original plastic radiator got a small crack at the top so I pulled it out and put in a nice big aluminum racing style radiator which is much thicker. Before putting it in I flow tested it with a garden hose to make sure there was no major issues. Now I hear a bubbling it sounds just like the water is boiling in the head however the temp gauge reads normal. The lower rad hose stays cold. So I pulled the thermostat and put a new one in. I even checked the new one prior to installation with hot water and a thermometer. Same Issue. So then I was thinking water pump may be bad but I can see the water moving with the filler cap off and with it on and reving the engine I can feel the line fill with water.
My only other thought was that my head gasket was leaking and I'm hearing exhaust sneaking into the cooling system but I hear the noise even with the car off. It doesn't seem to be losing any coolant either. When I pull the cap after a 2 mile trip it spews radiator fluid everywhere however. I even tried a new cap. Same thing.
Anybody have any ideas?
Oh and oil/ coolant are both clean and don't have any evidence of cross contamination due to a bad head gasket. :banghead:
It`s normal for the lower radiator hose to be somewhat cooler or even cool to the touch when at operating temperature. If I understand correctly, your concern is the gurgling sound you`re hearing, & not any overheating or running hot issues, correct? It seems to me that your cooling system is operating normally other than the noise, based on what you described. It`s possible that you have a stubborn air pocket in the cooling system thst needs to be "burped" out. Btw . . . is the heat working ok ? Inconsistent heat would be a sign of an air-bound system . . . :talon:
  • Wanted 6 bolt NT water pipe
    • chrisman287
