2G Crankshaft and bearings question
bmw335ikt
228
16
Sep 23, 2015
Crown Point, Indiana
I'm getting the Manley 88mm crankshaft. And my car is a 97 which the trust washers are attached to the main bearings. Should I stay the same or get the ones with the trust washers are separate. I just want to know if I would stay the same or if the Manley crank requires the other ones? Also acl or King bearings?
Thank you
Idk about which style thrust bearing, but brand wise, everybody runs ACL in these cars, in any case make sure you get tri-metal bearings if you are planning to make any kind of power.
:ohdamn:
Excellent........:rolleyes:
Find the serial numbers on your block and macth the exact yr, that will help you pin point your answer.
