crank won't spin tranny hooked up
Kyogie12
306
Feb 14, 2010
Boulder, Colorado
So i'm putting together my project car (95 gsx). When the engine was alone it would spin just fine. When the transmission was alone it spun by hand just fine. I put the two together and now i can't spin the crank? It's a 2g tranny on a 1g 7 bolt, but hooked up just fine....thoughts?
Just regular bolts...
Also another side question. So the slave isn't hooked up obviously, but should i be able to actuate the clutch by hand with the arm when it's all hooked together?
Turns out it was our makeshift pressure plate to flywheel bolt that was hitting the bell housing. A little bit of an angle grinder and all is well.
