crank question
clipto
2,316
5
Oct 8, 2011
Portland, Oregon
My mechankc said this is ok on the crank this line on it. Do you think its ok?
Should be fine, if not get a crank repair sleeve, that area is where the rear main seal rides.
Since you have the crank, make sure you get the press fit oil galley plugs/balls out so you can clean the crank proper.
  • Wanted 6 bolt NT water pipe
    • chrisman287
