Crank pulley specific to year/model?
I looked up the part on through the site you provided. The harmonic balancer can be had from the Mitsubishi dealer for a little bit cheaper and it should be the same for all 2G 2.0L Turbo. The reason it can not be 100% matched by them is because they are Chrysler, showing parts for Eagle only. There was no 1999 Eagle Talon so it will not be in their system as the correct application for a 99 Eclipse. That is the correct part number by the way.
The parts the same for any 4g63, 89-99. Just make sure if you have AC you get the one for AC.
That's the right part number.
