chrisgarza
- 31
- 0
- Mar 9, 2013
Raleigh,
North Carolina
Ok guys I am doing a pretty heavy rebuild on my 1998 GST. After a tear down and clean up I found a small crack in the wastegate flapper port. It is about 1/2" Long and does go all the way through to the outside of the housing. From what I have read this will effect my spool pretty bad. The car was holding boost and no noticeable creep before tear down. I found this one on ebay for $100. Not to happy about the VHT paint on the internals but I could clean it off. What do you guys think? Below is a list of current or purchased parts waiting for install.
http://i.ebayimg.com/t/Mitsubishi-EVO-3-Turbo-Turbine-Housing-TD05H-14b-16g-18d-20g-Eclipse-Talon-Laser-/00/s/MTYwMFgxMDk5/z/25oAAMXQTghRR8ZR/$T2eC16hHJI!E9qSO-ShmBRR8ZQu-(Q~~60_57.JPG
http://i.ebayimg.com/t/Mitsubishi-EVO-3-Turbo-Turbine-Housing-TD05H-14b-16g-18d-20g-Eclipse-Talon-Laser-/00/s/MTEyNVgxNjAw/z/jZ4AAMXQySpRR8ZW/$T2eC16RHJIQE9qUHsjyKBRR8ZWDDuw~~60_57.JPG
http://i.ebayimg.com/t/Mitsubishi-EVO-3-Turbo-Turbine-Housing-TD05H-14b-16g-18d-20g-Eclipse-Talon-Laser-/00/s/MTIxOVgxNjAw/z/Lk4AAMXQ9qpRR8Zs/$T2eC16RHJIQE9qUHsjyKBRR8Zryp)g~~60_57.JPG
BC Forged Internals - Installed
Evo III GT with M.H.I. TD05 Internals - Being Balanced @ G Pop Shop
FP 16g Comp Wheel (Super Back) - Being Balanced
FP 18 p.s.i. Wastegate Actuator - Waiting for install
34mm Wastegate Flapper (Stainless) - Installed but will replace on new housing
Ported and Polished Turbine Housing - Cracked!!!!
Ported and Polished 02 Housing - Done waiting for install
Stainless 4-2-1 Header - Waiting for install
MishiMoto S-Line FMIC (Black Powder Coat) - Waiting for install
Custom 2.5 IC Piping (Black Powder Coat) - Waiting for install
Greddy Type S B.O.V. (NGR Diaprhagm/Single Spring Mod, Recirc) - Done
Greddy ProFec Type S E.B.C. - Installed
APexi SAFC-2 - Installed
HKS 90 Second Timer (J-Spec) - Installed
MSD Ignition Coils - Installed
MSD 8.5mm Wires - Installed
NGK Plugs - Installed
ACT 600165 11.9lb Flywheel - Installed
XTD Stage 3 Clutch - Installed
Eibach 1" Springs - Installed
Catch Can with Filter - Installed
Optima Red Top - Installed
RC Racing 660 Injectors - Installed (Just cleaned with injector machine)
Wahlbro 255 - Installed
A'Pexi N1 3" S.S. - Installed (No Cat)
Custom Made (Black Powder Coat) J-Pipe - Waiting for install
Fluidyne 2-Row Radiator - Waiting on install (I may have frame powder coated)
AEM Air Filter - Waiting on install
Injen Air intake - Waiting on install
18x8 Team Aerospeed GT-RS - installed
BFGoodrich Eagle GT's - Installed
EGR Delete
Balance shaft removal - done
VIS Evo Carbon Fiber Hood - Installed
Blitz Full Body Kit - Removing front bumper for Talon 2gb, shaving skirts, keeping rear bumper, shaving spoiler for notchback look
I may have missed a few things
Future mods just waiting to purchase
MSD DIS-2
DSMLink v3 (Replace SAFC-2)
Electric cut out for exhaust
Talon 2gb front number (shaved emblem)
Anyway Thanks for reading and please let me know what you thing on the ebay housing. Supposedly it is a genuine MHI Evo 3. Thanks Guys Chris
EGR Delete
MSD DIS-2
