cracked manifold. help
Shmikey
Dec 5, 2005
Boca Raton, Florida
i just realized that my exhaust manifold is cracked (real bad like almost a hole kindda thing).
anyways my car is BONE stock, and i really wanted to do my mods in order (intake/exhaust > turbo timer > guages > downpipe > then manifold) , but this has pretty much forced me to do the manifold before anything else.
if i get a SBR manifold will i lose power since my car is stock? i mean it cant be as bad as the hole i have in my manifold right now (turbo doesnt spool, engine bay gets HOT as hell = intake air is also hot as hell). i dont wanna get a stocker, cause i did wanna eventually run something bigger. so would this be a good choice?
btw i will be building head + bottom end, putting a e316g during easter break (well thats the plan)
-Mike
Shmikey said:
if i get a SBR manifold will i loose power since my car is stock?
No.
You could always get it welded... it's kind of like throwing money away since you'll be upgrading eventually, but it's an option - and it will be much less expensive than buying a new manifold; especially if its only temporary.
No, you won't lose any hp by using the SBR manifold. In fact, you'll probably gain some. If I was you I'd buy a EVO III manifold. I never heard of any cracking and they flow 20% better than the stock 2g manifolds which means more hp.
