Courbeau 4 point harness install question
WhatV8
Mar 13, 2003
Naperville, Illinois
I just purchased the above harness and tried to install it yesterday. It is the snap on version (not the bolt in) and comes with eye hooks. The two rear and the left hooks fit just fine. But I can't find where to mount the right side. The belt on that side looks like it's built into the seat, so the only place I could find was the bolt at the rear of the seat bracket. But this is a bit too small. I've been trying to get another eye hook, but the places I've tried don't have them. So where has everyone else mounted them? If you've used the same bolt on the seat bracket, where did you find a smaller heavy duty eye bolt?
Thanks,
Chris
I was able to get things to work after removing the driver's seat. After taking it out, I could see the bolt holding the right side of the belt. Unfortunately, that side is much too long now. So I think I have to take the belt in to get it sewn up shorter. But now I have a different question. For those with an aftermarket seat (I think I'll be going with the Corbeau FX1 Pro), how did you secure the right side since the stock belt is bolted to the seat? Did you have to secure it to the back of the track like I had originally thought I'd have to do?
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
