Couple upgraded SMIC questions...?
truwarrior
1,422
6
Dec 19, 2002
I'm thinking about upgrading my sidemount because I want around 300hp and sleeper look. Probably gonna get a T28.
Will I get decent gains with the T25? Also with the upgraded SMIC has anyone made any special ducting out of fiberglass or anything to direct the flow into the SMIC? Kinda like the stocker but bigger? Thanks.
No decent gains on the T25, doubt you can barely heatsoak the stock IC core with that turbo.
I don't think monkey-rigging some forced air into the SMIC is going to do anything worth noticing. The larger core itself will work fine, and seeing as the T28 will be near its limits at 360HP then you will be just fine.
I would suggest the dejontool Super Sidemount, I am purchasing one as well.
  • Wanted 6 bolt NT water pipe
    • chrisman287
