couple more fuel questions
spic21
240
May 14, 2010
albany, Louisiana
im installing my fuel regulator on 90 talon tsi. i have all the fittings i need except:
(i am using all 6an fittings)
what fitting do i need to screw in to fuel filter?
what do i need for the return line?
and last but not least i need the spacers that go between the fuel rail and head that fuel rail bolt go through. i was use some piece of alum. tubing i cut but there just a little to fat i dont sit right in the slot.
i bought almost everything from local race shop and this is all in need to finish. tx
FUEL FILTER ADAPTER : 12MM X 1.25 TO -6AN
-6AN to 5/16" Barb Fitting and then run a rubber fuel hose from this to your original fuel return line.
OEM FUEL RAIL SPACERS PN: MD095402
:dsm:
