could this be a bad turbo or HG?
cardot33
182
Apr 2, 2009
Amboy, Illinois
hey, My 90 Talon TSI AWD is just recovering from some transmission problems and now it seems like it's shifting pretty well after a trans rebuild, ACT clutch, and a couple other things. now I noticed the oil seems very thin, like watered down. I've been losing a lot of coolant and it has to be going somewhere, but the dipstick readings don't seem to have any sort of mix with coolant. if I take the oil fill cap off, that's where I can find some milky oily stuff. the car doesn't have any white smoke while running though. I'll have to do a compression test a little bit later, I have to get a battery charger first.
so what's my problem here? do I have a bad turbo blowing coolant up into the head or something? how can I tell that it's a bad turbo and not the HG? it's pretty odd that the oil is so thin, but only mixed in the head. I got curious and took off the oil filter, none of the oil I found there was mixed, but it was really thinned out.
I could really use some help figuring out what's wrong. I've really lost my faith in this car in the past couple months.
Its your head/head gasket if your oil looks milky then you have coolent leaking into it so I would say DONT drive the car till you fix it you can cause alot more damage
Probably head gasket... Unfortunately, the white smoke and mixture on the dipstick are the only ways of checking that I know of. If its just the under side of the cap showing mixture, then the cap might not be getting a tight seal, or you could have a leaky valve cover gasket (mine was caused by both).
But I would be willing to bet its the head gasket.
Maybe do an oil change and get some thicker oil. I use Quaker State 10W-30 in the summer and Quaker State 5W-30 in the winter.
Another vote for head gasket, you can also check the dipstick for bubbles in the oil. Not a 100% diagnosis, but it will help further prove the theory. Like it was said above, DON'T drive it (very far, at least) and throw a compression tester on it to confirm it before shelling out the money for all the crap that goes into a HG swap. On a side note, unless money is super tight, go ahead and do yourself the favor of picking up a water pump and new belts while you're in there. :thumb:
well, I was going to do a compression test, but then my 5th starter failed on me. I have no idea how or why, but it's pretty ridiculous. maybe the 4th time using the starter? I've spent way to much money on this thing, I haven't been able to drive it, and the weirdest things just keep breaking and costing me money. I'm pretty sure I'm just going to get rid of this car as-is. the sooner, the better.
thanks for the help anyway guys, this car is just too unreliable to be worth fixing.
