Correct me if im wrong 4g64
mulldawg
52
May 7, 2006
Mount Pleasant, Michigan
Ok well my motor is done... oil pump froze up and engine is shot. I was thinking about all my options and what i should do to my gsx. i then realized what i had sitting in the driveway(other car). Its a 92 plymoth colt vista awd. it has a 4g64 block :). soooo am i right in thinking that all 4g64 blocks are the same and can be put into my gsx????
4g64 is the motor used in the sypder gs n 3rd gen 4 cyl. u could proly use the block n put the 4g63 head on it.
Yeah you can use the 4g64 block with 4g63 head, but you will need galant dohc cams and timing belt. All the turbo stuff bolts up. If i can remember right there is no knock sensor though. Good luck :thumb:
