correct ebiachs for a 1g?
68442
639
5
Oct 14, 2007
Des Moines, Iowa
Are these part numbers correct for a 1gb? They didn't correct camber so seeing if they are even proper parts. Couldn't find much info searching.
Looks like 1G AWD Pro-kits. Why would you think they would correct camber? The lower you go, the more you'll affect camber. These springs aren't that much lower than stock, so the fronts should still be pretty close to zero camber, and the rears should be well within range on the stock eccentric bolt adjustment to get it right. Have it aligned, and if they can't get it within spec you most likely have another issue.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
